Hello forum users,
What is the proper code syntax to name four 3D views with corresponding elevations, e.g., N, W, S, E instead 1 to 4?
I believe it is enough to modify the code block with 1…4 node only?
Hello forum users,
Hello @pawel.lorenc and welcome here…do you mean something
Yes,
Thank you, that’s exactly what I was looking for!
Hello, normal, Mr. Sovitek is never in the west ![]()
cordially
christian.stan
Could you clarify, why there is a null at the end?
to anticipate the case where it is neither 1,2,3 or 4 cordially
christian.stan
heheh yes Christian just try stay home ![]()
@pawel.lorenc
I just give it a null so you only can get 1…4 trough, but you can use the input as well if you want the rest list go trough,here is an exemple…but should doesnt matter in you exemple as you only feed in 1…4
