Code node does not appear in dynamo, reference image
It depends on what kind of node it is.
If it’s a node that can be written as a design script then you can go from node to code but if it’s a node made by C#, then it can’t be translated in to code. That is the differents between the nodes that you have in your picture.
There is a difference if you right click on the node or between in.
As you see in my example I get the Node to Code in the second picture when I right click between the nodes but it doesn’t appear if I right click in the nodes in the first picture.
In the second picture you also see that Dynamo create the Code script from the nodes
Reasons node to code might not work:
- Some nodes don’t have names which track to the actual function calls.
- Nodes in a function state cannot be converted
- Nodes who’s class have namespaces conflicts (I have had some issues in Civil 3D)
- Nodes which require a UI or have a Dynamic UI, such as dropdowns, number sliders, watch nodes, etc.
Exactly as @jacob.small mentioned ![]()
For the majority they are UI nodes which requires user interaction (i.e. Color range or Python nodes) and/or are dynamic (i.e. Watch node ).
C# nodes, also known as ZeroTouch will mostly convert with the aforementioned caveats from Jacob.
