Hi All -
Is there a way to look into and review/edit the underlying code withing a given node?
Thanks!
Hi All -
Thanks!
Thanks Zach.
I was browsing though the code. Very interesting - Is it in F#?
Anyhow, I didn't see anything for extruding solids. Do you know where that might be defined?
Thanks again.
You bet, everything is available for inspection on the Github site. Check out the node code here:
https://github.com/ikeough/Dynamo/tree/master/src/DynamoCore/Nodes
Dynamo’s source repo is here:
and the specific link from before is here(ish):
going to go ahead and close this topic as it is pretty old.
