Code Block -reading list values
Hi, I have a problem with a code block.
If I take the individual readings from the list I get the correct values.
If I use number generation within the specified range instead I get wrong readings. Since I have to read 226 values, how can I solve this ?
Thank you.
@DScad ,
whats the error message ?
maybe you are out of range? or you have nulls ? or you are indexing wrong …
KR
Andreas
List.GetItemAtIndex should do the trick; might need two of them though.
Thanks !!
