Hi, could anyone explain why my code block is behaving the way it is? The two code block is identical and input in both of them is a list so why is the output different and how do i solve this?
The bottom version is using “”, not “1” like the top one for No
In the first image, here you could try string to number or do so a== “20” and a== “24”…
Hope it helps
Thank you that works, do you know why? Whats the difference in the lists?
the first one you feed in strings, the other one intergers
