Code Block input issue
Need to use path in a list as input for the code block. It only allows one item from the family list to pass thru.
I really need the input from here. How do I use this in my code block?
If I use a code block for input it works fine.
A Directory Path node output works too. (no not need it this way)
this is because the path in first picture is a list, use Path[0] instead of path
Thanks, watched that tutorial last week and forgot all about it. Solved.
@stephen.donahay Hi stephen ! Can you tell me who you defined inputs for the code block ??
@Ahmed_Ramy ,
it is just creating variables + strings …
