Code Block: Filter by conditional statement, eradicate nulls
I am trying to learn Code Block syntax, and currently toying with creating my own List.FilterByBoolMask with a simple statement; “If Input==10?”, Else; Output==null. I would love to filter the output from the alternative value, and just output the In list. Is this possible within the same Code Block?
Hi @Tue_Kappel - You can keep chaining conditions like so - Is this what you are after?
You can also call the dictionary outputs of nodes like so:
And you can replace Nulls like so :slight_smile:
Something like this also may work
To expand on what @solamour indicated around pulling values form a dictionary:
To call the Dynamo function and only return the ‘in’ dataset:
List.FilterByBoolMask(list,filter)['in'];
To be clear, the reason you need to call for the value from a dictionary via key (the ['in'] in the above statement) is that any node with multiple outputs in Dynamo is actually returning a dictionary, where the keys are the output names.
Another way to do this via your own function is as follows. You need to leverage imperative code, a floor loop, and an if statement in this, so it isn’t for the faint of heart. However for those same reasons it’s a good learning exercise. Towards that end I’ve included a comment before each line to outline why I wrote it.
//define the function name, and inputs with structure
def FilterList (list: var[], boolMask: bool[])
//start the definition block
	//start the return statement as an imperative code block
	return [Imperative]
	//start the imperative code block
		//define a new list for results
		results = [];
		//define a for loop to iterate over th indicies of the list
		for (i in 0..List.Count(list) )
		//start the for loop code block
			//get the mask at the index
			msk = boolMask[i];
			//define an if statement for the mask
			if (msk)
			//start the if statement block
				//redefine results to include the item from the list
				results = List.Join([results, list[i]]);
			//close the if statement block
		//close the for loop
		//define the output from the imperative block
		return results;
	//close the imperative block
//close the definition
The results in action:
thank you all for great suggestions. I will try them all, and try to understand. -None of them what i was dreaming of, but all the more teaching moments for this simple mind.
I found the solution i was looking for…..-List.Clean can remove the null values, and throw away indices via the false value. So i’m left with the list of elements testing positive.Succes!
One liner for the pythonistas
Alternative
Nice one :wink: and another maybe, but not so cool as yours :wink:
hahah see now its the same as your alternative :wink: forget it :wink: really love the first one…
hi
edit: nice types in output on codeblock, I like it a lot.:ok_hand:
cordially
christian.stan
