Closing all Excel processes in python script
Like many other people, I am having trouble getting rid of all the excel processes when I run excel operations through a python script. Now I am down to one lingering process.
I did an earlier post, but I have since done some more testing, and I have manage to reduce the script.
Some of the things I tested can be seen in the old post here: Excel background process not closing after running python script
My current script is:
clr.AddReferenceByName(‘Microsoft.Office.Interop.Excel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c’)
from Microsoft.Office.Interop import Excel
from System.Runtime.InteropServices import Marshal
def tolist(obj1):
if isinstance(obj1,list):
return obj1
return [obj1]
path = IN[0]
macroName = IN[1]
solverPath = IN[2]
data = tolist(IN[3])
incell = IN[4]
outcell_start = IN[5]
outcell_end = IN[6]
sheetname = IN[7]
out_list=
for i in range(len(data)):
ex = Excel.ApplicationClass()
ex.Visible = False
ex.DisplayAlerts = False
ex.ScreenUpdating = False
workbook = ex.Workbooks.Open(path)
ws = workbook.Worksheets(sheetname)
sol = Excel.ApplicationClass()
sol.Visible = False
sol.DisplayAlerts = False
sol.ScreenUpdating = False
ex.AddIns(“Solver Add-in”).Installed = True
solver = sol.Workbooks.Open(solverPath)
out_bf=ws.Range[outcell_start,outcell_end].Value2
if ws.Range[incell].Value2 == data[i]:
#Effectively → Do nothing
out_af=out_bf
ws.Range[incell].Value2 = data[i]
ex.Run(macroName)
#The workbook and solver is closed
workbook.Close(True)
solver.Close(False)
sol.ScreenUpdating = True
sol.Quit()
Marshal.ReleaseComObject(ws)
Marshal.ReleaseComObject(solver)
Marshal.ReleaseComObject(workbook)
Marshal.ReleaseComObject(sol)
#The workbook is reopened to collect output
out_af=ws.Range[outcell_start,outcell_end].Value2
out_list.append(out_af)
ex.ScreenUpdating = True
ex.Quit()
Marshal.ReleaseComObject(ex)
OUT=out_list
My guess is that there is a COM object which I have not released, but I can’t figure out which.
I don’t know if I dare say this, because so many times I’ve thought I solved the problem, only for lingering processes to appear the next time I test it - But for now it seems that I have gotten it to work.
The problem seems to be opening and closing excel applications multiple times in one script. So I have reworked the structure of the script, and I think I actually prefer it.
For some obscure reason though, when I loop it 4 times (and potentially divisible by 4), one process pops up.
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
def tolist(obj1):
		return obj1
		return [obj1]
path = IN[0]
macroName = IN[1]
solverPath = IN[2]
incell = IN[4]
outcell_end = IN[6]
sheetname = IN[7]
out_list=[]
ex.Visible = False
sol.Visible = False
		#Effectively -> Do nothing
		out_af=out_bf
		ex.Run(macroName)
	workbook.Save()
	workbook.Close(False)
	#First Session is closed
	#A new session is started
	workbook_out = ex.Workbooks.Open(path)
	ws_out = workbook_out.Worksheets(sheetname)
	out_af=ws_out.Range[outcell_start,outcell_end].Value2
	workbook_out.Save()
	workbook_out.Close(False)
solver.Close(False)
sol.DisplayAlerts = True
ex.DisplayAlerts = True
sol.Quit()
ex.Quit()
Marshal.ReleaseComObject(ws_out)
Marshal.ReleaseComObject(workbook_out)
OUT=out_list
Thank you for this!
