Closed point to line
I am trying to select a layer from dwg plan and made get the center point of some elements like doors and try to get the closed point to grid line but I have a conflict to sort list points of doors with a list of lines of the grid to can place doors in walls
some of the points need to sort with line maybe I can use sort by key and the short distance between lines and point that will be the key.
Hi @MAIA17112
Use Geometry.IndexByDistance custom node from springs nodes:
Hi @Kulkul
thanks but I wanna sort point not just line which means I want points of doors that had sorted as output do you get my point?
Switch the inputs at Geometry.IndexByDistance.
@Kulkul test nodes10.dyn (31.1 KB) it’s not working with me still have the same output as lines not points test plan.dwg (102.0 KB)
@Deniz_Maral please can you help me to solve this deniz?
Are you looking for something like that?
test nodes1_forum.dyn (42.0 KB)
what’s the name of the package this node included in it?
Clockwork Package
thanks @Deniz_Maral it’s working now.
