Points from dwg with Python
I have some Python dwg codes that can filter layers, polylines and points
for the last one i like to extract the point coordinates by layer name. everything is working except to get the points coordinates. anyone an idea? this code is working well with polylines.
In the picture the result i like to get under the Element.Geometry node. But my Python script gives the error…
# Import RevitAPI
clr.AddReference("RevitAPI")
geo_opt = Autodesk.Revit.DB.Options()
dwgImport = UnwrapElement(IN[0])
layerName = IN[1]
# Layer name to String
for name in layerName:
x = name
# Get DWG geometry
geometry = dwgImport.get_Geometry(geo_opt)
points = []
list = []
# Get geometry in DWG (Points)
for geo_inst in geometry:
    geo_elem = geo_inst.GetInstanceGeometry()
    for point in geo_elem:
	    element = doc.GetElement(point.GraphicsStyleId)
	# Get Layer Names
	layer = element.GraphicsStyleCategory.Name
	is_point = point.GetType().Name
	if is_point == "Point" and layer == x:
		list.append(is_point)
		for pts in point.GetCoordinates():
			points.append(pts)
OUT = points
I think it’s because Point Class has no GetCoordinates method, but a Coord property.
http://www.revitapidocs.com/2019/81467732-3105-bd24-a6a5-b276a3c3f8af.htm
give a try replacing
point.GetCoordinates() with
point.Coord
I tried what you said but it gives you the following error:
With a little change in the code i get the coordinates. So that’s good.
Now i only have to figure out why element.Geometry gives me other point.coordinates than Python?
Solved :slight_smile: i had to make the translate from feet to mm and create Point.ByCoordinates.
