Longtime reader, first time poster, as you can probably tell from below I haven’t yet figured out how to properly post code, sorry about that in advance.
I was using the Clockwork node “element.Location” to filter out unplaced rooms, but one day it just started giving me all false’s on the Has Location output. I uninstalled all my nodes and reinstalled, and I thought that fixed it but it’s only working correctly half the time and I’m stumped as to why, I don’t know much about Python but it doesn’t make sense to me why it would stop function correctly. I don’t see anything in the script that would be affected by another package being installed, am I right? Dynamo version 1.3 and Clockwork 1.x, Revit 2017.2
import math
clr.AddReference(‘RevitAPI’)
items = UnwrapElement(IN[0])
pointlist, curvepointlist, ispoint, iscurve, curves, haslocation, angles, hasrotation = [], [], [], [], [], [], [], []
for item in items:
try:
# points and text notes
pointlist.append(item.Coord.ToPoint())
ispoint.append(True)
iscurve.append(False)
haslocation.append(True)
hasrotation.append(False)
except:
try:
loc = item.Location
if loc.ToString() == ‘Autodesk.Revit.DB.LocationCurve’:
# line-based elements (e.g. walls)
curvepoints = (loc.Curve.GetEndPoint(0).ToPoint(),loc.Curve.GetEndPoint(1).ToPoint())
curvepointlist.append(curvepoints)
curves.append(loc.Curve.ToProtoType())
ispoint.append(False)
iscurve.append(True)
elif loc.ToString() == ‘Autodesk.Revit.DB.LocationPoint’:
# point-based elements
pointlist.append(loc.Point.ToPoint())
try:
angles.append(math.degrees(loc.Rotation))
hasrotation.append(True)
except:
# check for host objects outlines (floor slabs etc.)
try:
refs = HostObjectUtils.GetTopFaces(item)
blines = []
bpoints = []
for ref in refs:
try:
boundaries = item.GetGeometryObjectFromReference(ref).GetEdgesAsCurveLoops()
for loop in boundaries:
cloop = []
clooppoints = []
for line in loop:
cloop.append(line.ToProtoType())
curvepoint = (line.GetEndPoint(0).ToPoint(),line.GetEndPoint(1).ToPoint())
clooppoints.append(curvepoint)
blines.append(cloop)
bpoints.append(clooppoints)
except:
pass
if (len(blines) > 0):
curves.append(blines)
curvepointlist.append(bpoints)
haslocation.append(False)
except:
except:
try:
# curves
curvepoints = (item.GetEndPoint(0).ToPoint(),item.GetEndPoint(1).ToPoint())
curves.append(item.ToProtoType())
except:
OUT = (pointlist,curvepointlist,curves,ispoint,iscurve,haslocation,angles,hasrotation)
