Clockwork, Project Parameters noeud doesn' t work
Hi guys
I try to purge unused project parameters with dynamo, I find this script on the internet easily, but the Clockwork package noeud ProjetParameters Noeud doesn’t work. Someone could help me?
Many thanks.
Yuan
Remove the Document.Current node. It’s not the correct Document type (Dynamo Revit.Application.Document) required.
You’ll need to upgrade to the 2.6.0 package version (which addressed a compatibility issue for Revit 2023+):
Thank you very much.
But i get another issu, I could not delete the shared parameter unused i find out.
The warning tell me, the ID of elements could not be found.
Do you know why?
Thank you again
