Clash Detection - pipe x "linked" structural framing
Hi Guys!
I’m trying to make a script to clash detection between pipes and structural framing (the structural framing is a link) but the script is not working.
I’m try to use two nodes to clash detection, I will show the nodes with the warning message on the images bellow:
Clash detection BimorphNodes
Clash Detection Geometry.intersect
tks for the help!!! :grinning:
@mauriciolimax,
try Element.Supported from Bimorph to check if Structural Framing supported.
The first warning provides the solution; bimorphs has a node meant to be coupled with Element.IntersectsElement for linked elements:
As for the second warning, you are feeding Elements and not Geometry. Use this in between:
was this ever resolved? do you mind sharing how did you solve this?
Share your sample file, we’ll help you.
