I have a surface analysis table in Civil3D, and when I try to extract this data as shown in the picture below, Dynamo does not capture the values after the decimal point.
Can you upload that drawing?
Here are the files.
Earthworks.dwg (3.1 MB)
Selecting Table Objects and Export to CSV.dyn (14.3 KB)
When using export to CSV, id’ont get the problem.
Weird, here I get the results as expected:
Technically, the function explodes the table to memory objects, which are MTexts and lines. It sorts the MTexts on the location property, then it returns strings only. There is no number parsing at all.
If you export the result of the AllData to a file, do you get the expected results or the shown results?
