IS THERE A WAY TO IMPORT A TABLE SIMILAR TO THE ONE BELOW (WITH APPROX 2700 LINES) WHERE THE DATA IS SELECTABLE BY THE ASSEMBLY UNIT AND MNEMONIC, AMOUNT AND WBS ELEMENT ARE BLANK WHERE THE FIELDS ARE FILLED IN BY THE DRAFTER.
| Mnemonic | WBS element | ASSEMBLY UNIT | Amount |
| RMAC | N.5XXXX.C.52 | ANCHOR - EXPAND / CROSSPLATE / BUST | 5 |
| RMAC | N.5XXXX.C.52 | POLE NON-WOOD BAND ATTACHMENT | 1 |
| RMAC | N.5XXXX.C.52 | POLE NON-WOOD BAND ATTACHMENT ADDL | 3 |
| RMAC | N.5XXXX.C.53 | POLE TAG | 1 |
| RMAC | N.5XXXX.C.53 | REARRANGE XFER AERIAL SVC DROP | 1 |
| RMAC | N.574766.C.53 | REARRANGE XFER AERIAL SVC DROP ADDL | 4 |
| RMAC | N.5XXXX.C.56 | REARRANGE XFER POLE ATTACHMENT | 1 |
| RMAC | N.5XXXX.C.56 | REARRANGE XFER POLE ATTACHMENT ADDL | 3 |
EXPORT TO A SPREADSHEET THAT TOTALS (PIVOT TABLE) ALL THE ITEMS. OR JUST A STRAIGHT EXTRACT OF THIS DATA TO EXCEL.
I AM LOOKING FOR A WAY TO SELECT THE LINE ITEM AND ADD TO THE DRAWING THAT STARTS FROM A TEMPLATE WITH THE TABLE BUILT INTO THE TEMPLATE.[DATA TABLES]
FOR PHOTOS/ENGLISH VIDEO SEE THE LINK BELOW
(Re: Data tables - Autodesk Community)
