Hi Jacob,
I have added Object.Geometry before string as you mentioned still Geometry.fromSolidDef() fails… any other suggestions. Adding to this I’m using Dynamo for Civil 3d to convert Autocad Solid to JSON file. Since my Autocad solid is complex exporting Autocad Solid to Revit by converting the solids into SAT file and importing the same in Revit using dyanamo is not helpful. I can see more void in solids due to which I’m trying to use this method. It would be very helpful if you can suggest any other ways to convert Autocad solids to Revit solids other than using SAT and IFC for exporting Solids from Autocad and recreating in Revit manually or by using Dyanmo.
Try skipping the string from object.
Hi, share the dyn file and dwg so we can help you. Thanks
Thank you. I tried two scripts. One with name of corridor.
import from c3dv2.dyn (32.1 KB)
Import korytarzy.dyn (28.3 KB)
import.dwg (5.6 MB)
Are u look at my files?
Thank u very much ![]()
