Hi everyone!
I’m a bridge modeller
I want to directly export Civil3D Corridor to Revit as Generic Model.
I want to be able to control the region that is created from Civil3D in Revit
I’m using CivilConnection in Dynamo
Why do I still get BaselineRegion start at 0, when it is actually starting at 3 in Civil3D?
I’ve tried adding a section view at 3m but it’s still the same
[Bridge] BridgeSegment Creation.dyn (32.2 KB)
Dynamo Bridge C3D Test.dwg (985.5 KB)
Is it possible to create Revit Element by controlling the Region in Dynamo?
Or does the Region need to be set beforehand in Civil3D.
If I should be able to us Dynamo to set the region, what am I doing wrong in the DYN attached?
If the Region needs to be set beforehand in Civil3D, I’ve done that as well, but it’s still not working. What am I doing wrong in my DYN attached?
Thanks!
