Civil 3D: Property definition order
Hi, is it possible to set property definition in same order as defined in Dynamo or later using API?
Test Dynamo file and dwg is attached:
01_D4C3D_Pset_testPropetyDefinitionOrder_01.1.dyn (17.9 KB)
Test_propertysetDefinition.dwg (466.7 KB)
Thank you in advance
Lukas
Good question!
Have had the same thing in my mind.
Would also be great to be able to set which order the properties could be exported or send to for example a excel sheet.
