import sys
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
clr.AddReference('Civil3DNodes')
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
civdoc = CivilApplication.ActiveDocument
PROFILE_VIEW = IN[0]
def move_labels(PROFILE_VIEW):
if not hasattr(PROFILE_VIEW, "__iter__"):
PROFILE_VIEW = [PROFILE_VIEW]
error_report = None
res = []
resp = []
resf = []
resa = []
try:
with adoc.LockDocument():
with adoc.Database as db:
sampleLineId = PROFILE_VIEW[0].InternalObjectId
objVIEW = t.GetObject(sampleLineId, OpenMode.ForWrite)
for i in objVIEW.GetPipeIds():
objpp = t.GetObject(i, OpenMode.ForWrite)
resp.append(objpp)
for i in objVIEW.GetFittingIds():
objpf = t.GetObject(i, OpenMode.ForWrite)
resf.append(objpf)
for i in objVIEW.GetAppurtenanceIds():
objpa = t.GetObject(i, OpenMode.ForWrite)
resa.append(objpa)
t.Commit()
except:
import traceback
error_report = traceback.format_exc()
if error_report is None:
return [resp,resf,resa]
return error_report
OUT = move_labels(PROFILE_VIEW)
May I know the ultimate goal of your idea so that I can help you?
The pipe (if it is straight or arc) can be turned into a FEATURE LINES
To get a geometry
can you attach
Example civil file
dynamo file
I just have a c3d file contains pressure pipe network and i need to get pipe geometries like centerline curve and solids.
I use civil3d toolkit package and itâs nodes does not generate required output so, I tried your python code and i get the upper results.
import sys
ed = adoc.Editor
error_report = None
res = []
resp = []
resf = []
resa = []
try:
#resp.append( objpp.Get3dBody().Area )
#resp.append( dir (objpp.Get3dBody() ) )
resp.append( objpp.Get3dBody())
resf.append(objpf.Get3dBody())
resa.append(objpa.Get3dBody())
t.Commit()
except:
import traceback
return error_report
It should be the CIVIL 3d 2021,2 version
before there is no mothed
With an update in Civil3D 2021.2, there is an update in PressurePipe API. Now there is a function available to get the solid body of a PressurePart
Itâs not going to be possible to mix Python code with nodes from the Civil 3D Toolkit. The furthest youâll be able to go with Python is to output an object from the Autodesk.Civil.DatabaseServices namespace, but then you canât use that object type with Civil 3D Toolkit nodes because everything is in a different assembly with completely different classes. This has nothing to do with Dynamo because these are object-oriented programming principles.
If you want to use Python and the API, then you have to use it all the way. In other words, youâll have to get the solids, curves, etc. via Python and not the Toolkit if you are getting the pressure pipe network and pipes/fittings/appurtenances via Python.
