how do control inner circle based by the outer circle? and how do create a surface between inner curve and outer curve
thanks,sir but how do control inner curve based by inner curve,and i need to change z value each point
Not sure I quite understand what you’re trying to do.
In my example the inner curve is controlled by the radius of the outer curve.
Also… not a sir
ya I like this but I want a smooth surface
what’s wrong this?
Warning: Face.Vertices expects argument type(s) (Autodesk.DesignScript.Geometry.Face), but was called with (Autodesk.DesignScript.Geometry.Solid).
