Hello Friends,
Is it possible to determine the widths or lengths of a surface (non-rectangular), either minimum or maximum values, I am only aware of the bounding box method to get values of regular shapes.
Hello Friends,
Not sure how well this would work but this is how I would start to tackle the problem:
A really bad drawing:
How do I group by parallel directions?
When you have the lines, you can get the direction using Line.Direction node and then groupbykey to organize them.
I am not sure how to group by keys… by vectors?
I am quite new here…
I would recommend against the route I suggested then. It is very code heavy and just to get lines grouped together required me to use a custom function to convert curves to lines (Surface.PerimeterCurves gives curves which have no direction vector) and a python script to take those vectors, normalize them, and absolute them.
Maybe someone else can offer a better strategy.
I would like to see it if you are willing to share
I didn’t get any significant progress done, only up to the grouping of lines by similar vectors and only made it work for if they are straight left/right or up/down.
Try to swap the Curve.TangentAtParameter for a Curve.NormalAtParameter. Got myself backwards as I typed up the workflow.
Changed it. Not quite sure where it goes.
is this with Curve.NormalAtParameter with the parameter at 0.5?
try it with 0 or 1.
just a hunch
Add a vector.Reverse node right after it. That should fix the angle issue.
still not successful
Thanks for the help, the green graph would actually work to get the minimum as you said. (I will have to forget the non parallel stuff)
Wondering if the cross product would work on multiple lists to get to multiple minimum values at the very end for respective multiple surfaces. Tried a few ways but couldn’t figure out
54 results when using cross product is not much if you have 38 inputs
