Hi, is there a way to check if a family is work plane based, preferably from the Family Type selection Node.
The reason is I made a script that inserts components in the documents following a certain number of parameters, But I need to use it for work plane and non-work plane based families.
So if I had a way to check I would change the workflow to match the family need.
Thank you all again.
