ChatGPT
I think i’m in love … With chatGPT :rofl:
Popups went from this:
To this
In a few hours :open_mouth:
Feel like sharing the fun? :wink:
https://chat.openai.com/chat
Haha I meant the hangman UI, but have had plenty of fun with chatGPT as well. It’s very handy for UI development, I’ve used some to troubleshoot xml/wpf.
Ah! Doh!
Bit of a mess atm as I’m still working on it the hangman game but:
NAME code (at work we have firstname.lastname as our log in so this works well).
import getpass
from System import Environment
sys_name = Environment.UserName
first_name = sys_name.split(".")[0]
OUT = first_name
And for the Windows popup
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
import System
from System.Windows.Forms import *
from System.Drawing import *
runme = IN[1]
class CreateWindow(Form):
    def __init__(self):
        self.Name = "Create Window"
        self.Text = "This is ©Hangman 2023, " + IN[0] + " !"
        self.Size = Size(400, 180)
        self.CenterToScreen()
        self.ForeColor = Color.Red
        label = Label(Text = "Enter a letter >>")
        label.Parent = self
        label.Location = Point(25, 20)
        label = Label(Text = "(Careful! Numbers will restart the game!)")
        label.Parent = self
        label.Location = Point(180, 20)
        label.AutoSize = False
        label.Height = 50
        label.Width = 150
        label.ForeColor = Color.Green
        self.textbox = TextBox()
        self.textbox.Parent = self
        self.textbox.Text = ""
        self.textbox.Location = Point(125, 20)
        self.textbox.Width = 40
        self.textbox.ForeColor = Color.Red
        button = Button()
        button.Parent = self
        button.Text = "OK"
        button.Location = Point(190, 70)
        #button.Width = 100
        button.Click += self.ButtonClicked
        self.footer = Label()
        self.footer.Parent = self
        self.footer.Text = "Hanging is barbaric! Why are you playing this game you monster!"
        self.footer.Location = Point(10, 100)
        self.footer.AutoSize = True
    def ButtonClicked(self, sender, args):
        if sender.Click:
            self.value = self.textbox.Text
            self.Close()
ThisGuess = ""
GuessedAlready = IN[2]
#Run the form
if runme:
	form = CreateWindow()
	Application.Run(form)
	ThisGuess = (form.value).upper()
if len(ThisGuess) != 1:
# Check if input is an letter
	if ThisGuess.isalpha():
		for i in GuessedAlready:
			if i == ThisGuess:
				ThisGuess = form.value
		ThisGuess = "Restart"
OUT = ThisGuess
I found asking it small bits of code worked better than asking it to write huge chunks.
Questions like,
"I have this bit of code:
xxxxx
How do I add a colour to the text? "
When I asked it to do 2-3 things at once it was a little erratic.
I also got the impression it was taking the mickey at some points… :rofl:
If you try using the openChatGPT pagkage in combination with it you could possibly get it to give you a random hangman word if you query it right. If you keep sending the inputs to an external file and read them in a loop structure you could potentially make a working and randomized hangman - cool!
It works already… sorta…
Few glitches. I’m rewriting it.
And thanks… I opened it to copy the code and now I’m coding again. Byee life :person_facepalming:
I’m using:
https://svnweb.freebsd.org/csrg/share/dict/words?revision=61569&view=co
But cleaned up as the word list.
And 2 more hours later I’ve made it worse…
ARGH
