I see there’s a Unit conversion node and since I wanted mm as my unit I did a number input setting conversion as mm -> mm and Watch node showed me correct value which I passed on but it didn’ do the job. I see lot’s of threads saying that you need to do the math to change units and recalculate foot to other units. Isn’t there a way to simply change the unit type (ie ft -> mm) while keeping the value without actual conversion?
- Which Dynamo version you’re using?
- What are the elements type you’re looking to convert?
ad 1 - 1.3.2
ad 2 - I want to input number which will be set as a mm unit to pass to other node as mm, not as feet.
Use Dynamo 1.3.3:
Click here http://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoInstall1.3.3.exe to download 1.3.3.
