Hi …
How do I represent an AutoCAD paper space viewport as a DynamoNode Viewport? … Or am I referring to CIVIL3DTOOLKIT custom object?
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.DynamoNodes import SelectionByQuery
editor = adoc.Editor
idata = IN[0]
ih = idata.Handle
hnint = int(idata.Handle,16)
hexa = Handle(hnint);
oid = adoc.Database.GetObjectId(False,hexa,0)
#res = idata.Handle
res = None
with adoc.LockDocument():
with adoc.Database as db:
# Place your code below
obj = t.GetObject(oid,OpenMode.ForRead)
if not isinstance(obj,Viewport):
vpid = LayoutManager.Current.GetNonRectangularViewportIdFromClipId(oid)
res = t.GetObject(vpid,OpenMode.ForRead)
res = obj
# Commit before end transaction
t.Commit()
OUT = res
vp-client-biind.dwg (2.8 MB)
handle-it.dyn (13.6 KB)
