Changing the Mark value of Air Terminals
Hi Everyone,
I am learning dynamo from few days , Actually I made a small script which is chnaging the Mark values of Air Terminals. Script is running smoothly in canvas but the problem is when I run the script through dynamo player Nothing is changing. Can you please look at it it would be very helpful
please find the below attached snap.
Thank you
Hi @irfankhan888969 ,
The Dynamo Workspace is different from the Revit Workspace. Like 2 different programs
So if you want to replace parameter values of Revit objects you need the FamilyInstance.SetParameterValueByName (or some similar name) node.
Hi @irfankhan888969 …you had to feed in string as the mark parameter is textparameter…
Hey, Thank you for your reply
