Automated Data Transformation and Assignment in Dynamo: Extending and Formatting Parameter Values
Hello Experts,
I’m trying to develop a Dynamo script using Python that retrieves the “Mark” parameter for all visible components in the current 3D view, extends each value by appending “1111”, changes the format to “12345678-1234-1234-1234-123456789012”, and then assigns the modified value to a parameter called “Comments”
But it’s not working and I’m getting this error message in the first comment
The code in the first comment
Error meesage
Code
Import necessary Dynamo and Revit libraries
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory, Transaction
Get the active document
Get the active 3D view
activeView = doc.ActiveView
Get all visible components in the 3D view
allVisibleComponents = FilteredElementCollector(doc, activeView.Id)
.OfCategory(BuiltInCategory.OST_GenericModel)
.WhereElementIsNotElementType()
.ToElements()
Start a transaction for modifying elements
transaction = Transaction(doc, “Extend Mark, Format, and Set Comments”)
transaction.Start()
try:
Loop through each component and update the “Comments” parameter
for component in allVisibleComponents:
Get the existing “Mark” parameter value
markParameter = component.get_Parameter(BuiltInParameter.ALL_MODEL_MARK)
Check if the “Mark” parameter has a value
if markParameter:
markValue = markParameter.AsString()
Extend the “Mark” value by appending “1111”
extendedMark = markValue + “1111”
Change the format of the extended value
formattedValue = “{}-{}-{}-{}-{}”.format(
extendedMark[:8], extendedMark[8:12], extendedMark[12:16],
extendedMark[16:20], extendedMark[20:]
Set the “Comments” parameter with the formatted value
commentsParameter = component.get_Parameter(BuiltInParameter.ALL_MODEL_COMMENTS)
if commentsParameter:
commentsParameter.Set(formattedValue)
Commit the transaction
transaction
Hi Sam, welcome :wave:
Your code has no indents (tab/4 spaces)
Use </> in the menu to format code and you could use a IDE like VSCode which can assist
Cleaned code
# Import necessary Dynamo and Revit libraries
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import (
    BuiltInParameter,
    BuiltInCategory,
    Transaction,
# Get the active document
# Get the active 3D view
# Get all visible components in the 3D view
allVisibleComponents = (
    .ToElements()
# Start a transaction for modifying elements
with Transaction(doc, "Extend Mark, Format, and Set Comments") as t:
    t.Start()
    try:
        # Loop through each component and update the "Comments" parameter
            # Get the existing "Mark" parameter value
            # Check if the "Mark" parameter has a value
            if markParameter:
                # Extend the "Mark" value by appending "1111"
                extendedMark = markValue + "1111"
                # Change the format of the extended value
                formattedValue = "{}-{}-{}-{}-{}".format(
                    extendedMark[:8],
                    extendedMark[8:12],
                    extendedMark[20:],
                # Set the "Comments" parameter with the formatted value
    except:
        pass
    # Commit the transaction
    t.Commit()
OUT = "What is your output?"
Hi Mike,
Thanks!
Output is assigning the modified value to a parameter called “Comments” for the same 3d component
