Change Views' Visual Style by Dynamo
Hi all,
I tried finding a solution for it in forum but to no avail.
So basically I want to change the visual style (which comes as hidden line as default) of views I’m creating automatically by dynamo, using dynamo.
(Hidden lines to Shaded)
Thanks in advance.
Regards,
Atharva Purohit
@atharva.purohit466SX check this one:
Can probably set it in oython using this property also:
The enumeration options:
I’ll give it a try and revert, thank you both!
Regards,
Good morning.
Did you manage to change the display style?
So what I did, I applied a template later after creating the view, using dynamo only.
Let us know if it works for you.
Regards,
atharvapurohit
