Change Text Note to Uppercase - revit 2017
I did it, but it didn’t work in revit, could you help me to do it, I am learning dynamo, it looks simple but It is the basis for my dynamo learning later. Thank you
You should connect the elements from your second node to the textnotes and the str output from the fourth to the value. Good luck!
It still doesn’t work. Could you have any ideas? Thank you for reply
Just to confirm, is this what you tried as a result of the advice from @dynamo_bronstijn?
If not can you post what you did try?
wow, i can do it ,sorry @dynamo_bronstijn, i misunderstand the answered, Thank You @jacob.small, @dynamo_bronstijn.
