Change slope ratio of slab - why Parameter Read Only?
I am trying to create a simplified way to enter the slope ratio of a slab using Dynamo (ie. 1"/12"). I tried to get and set parameters, but got a “parameter is read only” error.
Since my slab has 2 curved sides, I could not use Revit to define the slope based on the edge of slab. The slope ratio should match the one shown at 1"/12".
I could do some math and use the Slope Arrow to draw the change in height. I’d rather be able to change the actual slope, which is grayed out under Dimensions.
Parameter_is_Read_Only_slope
I tried GetParameter and the value was empty, which is currently accurate. I then attempted to SetParameter and I received the error:
Why can’t I change a “Read Only” parameter? Is there a way to change the value of read only parameters? Is there a way for me to enter the slope as a ratio to the SetParameterByName node?
  • Thanks! :grin:
