Change phase filter of View not working
Hi guys,
I’m trying to change the phase filter of a view. I couldn’t find a node for this. So I’m trying to code this.
Here is what I got:
It runs without warning, but nothing has changed in view. There must be something wrong in the code and I can’t figure why.
Thanks in advance.
Edit: I´m really sorry, the preformatted text works depending on something that I have not found yet…so, I´ll have to leave the code as it is for now.
You´re almost there, you just forgot a couple of things:
  1. Unwrap the phase filter too, it is a Revit element as the view.
  2. After the unwraping, you will have to use the transaction manager.
    #enable Python support and load DesignScript library
    clr.AddReference(‘RevitAPI’)
    #the inputs to this node will be stored as a list in the IN variables.
    view = UnwrapElement(IN[0])
    phaseFilter = UnwrapElement(IN[1])
    #place your code below this line
    view.get_Parameter(BuiltInParameter.VIEW_PHASE_FILTER).Set(phaseFilter.Id)
    #assign your output to the OUT variable.
    OUT =
Thanks! very helpful
Sorry for reviving this thread, will this work with ViewTemplates? I need to change the phase filters in multiple view templates…
I don’t understand phyton code. But since ViewTemplates are views too, i’m thinking if i can wire them to IN[0]
