I made a routine that changes the parameter indicated in the family by a number, but I need these numbers to be placed in an order. The order would be by the point in Z.
Hi @guilherme.woltmann,
Welcome to the Dynamo community.
I would suggest you try sorting the elements using SortByKey node.
Uoh Thank you!
List.SortbyFunction would be even easier
Can you show how?
Try this:
- Place a FamilyInstance.Location node but don’t connect anything into it.
- Then place a Point.Z node and don’t wire anything into that.
- Then place a Function.Compose node, add a second input and wire the FamilyInstance.Location and Point.Z in as inputs 0 and 1 respectively. Place a sort by function node on the canvas and use the element list as the list and the results of the Function.Compose as the function
Also, happy cake day. ![]()
