I want to change the paint of all the walls faces which have this(material in blue ) to material in red!
and I am having trouble in this
Connect from code block. I guess it requires a string input.
I have isolated the walls which have the first WF-01 paint on them but I can not understand how to take this code further…like now for the walls selected I need the faces which were painted with WF-01 and then re paint them with WF-02…and I need to be precise in this because I don’t want to change the paint on other faces of the walls
Currently I don’t want WF-01 on any of my walls in my project
You have to use that method
https://www.revitapidocs.com/2020.1/9268395e-a9cb-ff79-20ab-1ed261220513.htm
I am actually a new user of Dynamo and I don’t have much understanding of working on revit api or C#
Take a look at here:
I have seen these posts but I am not sure how to specifically select the faces I want to select
@sensiblehira continuing from the post of @Deniz_Maral and originally solved by @MartinSpence, I guess this can help you, the script will scan the faces for the old material and paint them with the new material.
#Import the Revit API
clr.AddReference('RevitAPI')
#Import DocumentManager and TransactionManager
#Reference the active Document and application
elems = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
oldMat = UnwrapElement(IN[0])
newMat = UnwrapElement(IN[1])
gOpts = Options()
for i in elems:
geom = i.get_Geometry(gOpts)
for j in geom:
face = j.Faces
for f in face:
#if doc.IsPainted(i.Id, f):
if f.MaterialElementId == oldMat.Id:
doc.Paint(i.Id, f, newMat.Id)
pass
OUT = 0
it is giving this error
File “”, line 27, in
AttributeError: ‘GeometryInstance’ object has no attribute ‘Faces’
it actually worked on some but some were left …I wonder why
@sensiblehira can you share a sample revit file?
// Paint any unpainted faces of a given wall
public void PaintWallFaces(Wall wall, ElementId matId)
Document doc = wall.Document;
GeometryElement geometryElement = wall.get_Geometry(new Options());
foreach (GeometryObject geometryObject in geometryElement)
if (geometryObject is Solid)
Solid solid = geometryObject as Solid;
foreach (Face face in solid.Faces)
if (doc.IsPainted(wall.Id, face) == false)
doc.Paint(wall.Id, face, matId);
I think you should check that GeometryInstances are solid or with try-except pass the elements.
gOpts = Options()
output=[]
for i in elems:
for j in geom:
for k in j.Faces:
if k.MaterialElementId ==oldMat.Id:
doc.Paint(i.Id, k, newMat.Id)
output.append("Success")
pass
OUT = output
I used this code instead and it did not return the error:
elems = FilteredElementCollector(doc).OfClass(Wall).ToElements()
gOpts = Options()
for i in elems:
for j in geom:
face = j.Faces
for f in face:
pass
OUT = 0
Thanks for helping me out @Deniz_Maral @Elie.Trad
