That’s a good start, is there any issue we can help to solve here?
Yna_Db,
No, that I know, it seems to be working properly. The only thing I saw was, in some cases I had to press play twice to change all the lines in the model. Other than that it works.
Thanks,
You could try to simplify it a little, did you see that?
http://dynamobim.org/forums/topic/change-linestyle/
Instead of filtering the element (in the bottom portion), filter the parameter value then get the unique items (or just the first) and use that as your input.
