Hi
I’m trying to change the types of floor elements by setting the parameter “Type”. Now, I need to do this with a string rather than using the Floor Types-node. Unfortunately that doesn’t seem to work.
Is there a way to achieve this?
Christian
Hi
Christian
Hi Christian,
Refer to this post http://dynamobim.org/forums/topic/cant-change-material-tag-type/
In your case its floor elements. Good Luck!
Hi Kulkul Thanks for you suggestions - unfortunately neither the OOTB way or Konrads node seem to work when the type input is a string with the type’s name. I cannot use the Floor Types-node as the input comes from room parameters and varies. Christian
Why are you still using Element.Id?
Change family type by filtered list
oops! cause I was trying it with other stuff as well. Looks like this works now! Thanks!
