Change design options with slider
Hello everyone
I want simply to have a slider that can change the design options - I’m using archi-lab’s “Get Design Options”. That feels like super basic and there have been several posts on that, but I couldn’t find anything related to this simple task. Hope you can help me out:
The Revit API doesn’t allow you to set the design option for an element programmatically. There are some workarounds suggested in this thread:
Actually I would like to change the design option view for the entire project, not a specific element. So a different group of families (furniture) would change for each value of the slider. The design option parameter value would be manually pre established for each family on the project so I was thinking on some way of simply filtering the families on the entire project view according to the design option value.
Families and Family Types themselves don’t have a design option parameter. Family Instances do, but as noted above you can’t set those using this method.
Hey, sorry if I’m being dumb…
I would describe that as Setting The Primary Option?
I would describe that as setting the Design Option visibility in the view?
It’s unlikely that either of those can be set through the API but let me know if I’m on the wrong track :slight_smile:
Mark
Jeremy is a god… https://thebuildingcoder.typepad.com/blog/2015/03/list-and-switch-design-options-using-ui-automation.html
Something else…
@Mark.Ackerley was on the right track here. The answer was indeed in this post: https://forums.autodesk.com/t5/revit-api-forum/how-do-i-get-and-set-the-view-design-option-override/m-p/5209907/highlight/false#M6995
So what Trevor noticed there is that a View has this parameter called “VIEWER_OPTION_VISIBILITY” and by default it looks like this parameter only controls what Tags to show/hide based on specified value, but it also has this hidden functionality where it actually toggles this setting:
This is perfect for us, since that will change the design option for the view. Here’s a little script on how to do that:
Also a short video of it in action:
I just tried this today and it didn’t work, for no obvious reason, so I did it this way… Pretty much the same…
