Hello, As you see I sorted curves so every 2 parallel curves which are close to each other are in a list but now the problem is that I want to make them have the same direction whether the positive or negative direction … how could I do that ?
Since you have lines:
- Get the direction of each.
- Find the angle from the first direction to the second
- Round that number
- Get the second line
- For each angle that is not 0, reverse the second line with a Curve.Reverse, otherwise just get the original second line
Thanks man, It has worked
