Hello, can you help me?
I need join points in other direction like on picture. I use list transpose for this but it is not work. Where I make a mistake?
Tahnk you
Tahnk you so muchy.
@Kulkul can I ask you one more question?
Do you know something about structural column justification? I need get my column to centre but it is not work correctly.
Thank you
@Michal_Nagy You need to feed elements to “SetParameterByName” node. Currently your feeding values in it. And also use flatten node for your elements.
