sure, here’s an updated picture.
Ceiling Tiles [Solved]
There is a different between the picture that i sent to you and the one u did, i took the input from different place !!!. i think you should pay attention before asking
You are so right, Im sorry! The script worked fine now and created the lines in Revit
Hi @Mohammad_Nawar
I am quite new to Dynamo and still learning. Just found your topic and was trying to apply your design script to my project. However it started to show some issue from beginning on Plane.Origin node. Just would like to confirm that I was using correct nodes.
Here is description:
Warning: Plane.Origin expects argument type(s) (Autodesk.DesignScript.Geometry.Plane), but was called with (Autodesk.DesignScript.Geometry.CoordinateSystem).
I also attached snapshots with a full graph and that particular node.
Thanks,
svetadiv
Hi @Mohammad_Nawar
Thank you for you prompt respond. I downloaded your script and tried to run it on a simple model. However it still did not work for me, run has started and could not complete. So, I had to end a task manually. Could it be anything it should be done or checked out in advance? Cheers,
svetadiv
Yes that’s true i beleive the issue that you are facing due to wrong input, so as you see in the picture below.
you need to feed the right input for the x and y value for example i was using tiles 2x4 so the inputs as in the above picture in your case if the tiles 200X300 you need to replace 2 and 4 with 200 and 300. i hope that was clear, let me know if you still facing any issue
Hi @Mohammad_Nawar
Thank you again. When I changed the size for tiling it started to work. However, there is a warning again on a big code block node. Here it is:
Warning: Method ‘Flatten’ has been deprecated, please use method ‘DSCore.List.Flatten’ instead
Method ‘Count’ has been deprecated, please use method ‘DSCore.List.Count’ instead
As a result I got that in Revit and it seemed to be not finalised. Do you have any idea how to remove that warning? Or do you think it does not make any difference?
Cheers,
svetadiv
I would like to apply that tiling to the ceiling creating line work in Revit. I believe I just need to follow up with your post to introduce additional nodes for that. Cheers,
svetadiv
