Hi there, can anyone help me with this issue please. I’ve created a DYN that use categories Node and the value keep changing anytime I move or change the folder of this file. For example As captured, it should be “Sheet” instead of “RVT link”
Your node could change because a Revit 2018 project file has less Categories compared to a Revit 2019 file.
So using the name gives you the item in the list of categories independant of the number of Categories.
@m.rijsmus is almost certainly correct - the number of categories change every release, and the drop down nodes store their values as an index not a string value so you won’t get consistency between Revit versions with that node.
Hi Alban, thanks very much it works perfectly.
Thanks Rijsmus, it happened to me once as you say. My dyn files working well in Revit 2017 but not really when I try in Revit 2019.
