Hello Dynamo Community,
I need to get the ID-object of BuiltinCategory.OST_Viewers but this category does not exist in doc.Settings.Categories. How to get it anyway? The ID is -2000278.
Kind regards!
for x in doc.Settings.Categories:
print x.Name, x.Id
Part Tags
-2000270
Alignment Station Labels
-2001017
Piers
-2006131
MEP Fabrication Hangers
-2008203
Pipe Insulation Tags
-2008155
Model Groups
-2000095
Analytical Floors
-2009639
Mechanical Equipment Tags
-2005009
Ramps
-2000180
Cable Tray Fittings
-2008126
Foundation Span Direction Symbol
-2005111
Communication Device Tags
-2008082
Air Systems
-2001008
Analytical Wall Tags
-2009653
Temporary Structure Tags
-2001042
Structural Connections
-2009030
Planting
-2001360
Ceiling Tags
-2005002
Annotation Crop Boundary
-2000547
Analytical Wall Foundations
-2009642
Furniture Tags
-2005006
Mass
-2003400
Air Terminals
-2008013
Pipe Accessory Tags
-2008056
Security Device Tags
-2008080
Window Tags
-2000450
Stair Tread/Riser Numbers
-2000944
MEP Fabrication Ductwork Tags
-2008194
Communication Devices
-2008081
Piping Systems
-2008043
Bodenablauf ohne Estrich.dwg
7560941
Fire Protection Tags
-2001051
Panel Schedule Graphics
-2008151
Bodenablauf ohne Estrich in Erstbeton.dwg
6348167
Detail Item Tags
-2005028
Reference Lines
-2000083
295777-1-CKTS9P3-1-3-GA - Querschnitt Maschinenhallenkran.dwg (3)
4749878
MEP Fabrication Containment
-2008212
Analytical Spaces
-2008185
Plumbing Fixtures
-2001160
Structural Framing Tags
-2005015
System-Zones
-2001001
Ceilings
-2000038
00016.dwg
4007648
00014.dwg
4007395
00015.dwg
4007518
00012.dwg
4007152
00013.dwg
4007276
00010.dwg
4006987
00011.dwg
4007022
Section Boxes
-2000301
-2008193
Bolt Tags
-2009056
Bridge Framing
-2006241
Elevation Marks
-2006045
Data Device Tags
-2008084
Pipe Segments
-2008163
Detail Spritzbetonerdung MAK-2.dwg
4521569
Anchor Tags
-2009057
Crop Boundaries
-2000536
Conduit Fittings
-2008128
SK-B-TW2-KRA-0000-P-4-015-01_00 (RP VT1 2000).dwg (2)
4147324
Sprinklers
-2008099
Approach Slab Tags
-2006211
Doors
-2000023
Lighting Fixture Tags
-2005008
Lighting Devices
-2008087
Assembly Tags
-2000268
Duct Tags
-2008003
RVT Links
-2001352
TRK OG Löschanlage GR.dwg
3284501
Curtain Systems
-2000340
Mechanical Equipment Set Boundary Lines
-2000987
Structural Rebar Tags
-2009020
Parking
-2001180
Ducts
-2008000
Detail Auflager Absenköffnung.dwg
6479917
Door Tags
-2000460
System-Zone Tags
-2001007
Internal Area Load Tags
-2005255
Revision Clouds
-2006060
Bridge Cables
-2006133
MEP Fabrication Hanger Tags
-2008204
Imports in Families
-2000196
Conduits
-2008132
Multi-Category Tags
-2005022
Abutment Wall Tags
-2006210
Analytical Isolated Foundations
-2009641
Flex Pipes
-2008050
Property Line Segment Tags
-2001269
Curtain Panel Tags
-2005012
Analytical Links
-2009657
Structural Trusses
-2001336
HVAC Zones
-2008107
Pier Column Tags
-2006222
Schedules
-2000573
TM_Kranbalken-Detail-1.dwg
4008086
Mass Floor Tags
-2003410
Electrical Spare/Space Circuits
-2008152
Hole Tags
-2009063
Medical Equipment
-2001046
Detail Spritzbetonerdung MAK-1.dwg
4521459
Site
-2001260
Analytical Columns
-2009636
Duct Systems
-2008015
Zone Tags
-2008115
Fire Protection
-2001049
Abutments
-2006130
Duct Placeholders
-2008160
Bearing Tags
-2006178
Reference Planes
-2000530
Cable Tray Tags
-2008131
Multi-Rebar Annotations
-2000970
Matchline
-2000193
Specialty Equipment Tags
-2005014
Duct Accessories
-2008016
Duct Fitting Tags
-2008061
Furniture System Tags
-2005007
Callout Heads
-2000538
Furniture Systems
-2001100
2020-10-06_Verteilrohrleitung_R00.dwg
4008055
Stirnwand-1.dwg
6047822
Stirnwand-2.dwg
6047846
Telephone Devices
-2008075
Lines
-2000051
Wires
-2008039
Pipes
-2008044
Audio Visual Devices
-2001055
Profile Tags
-2009064
Structural Stiffener Tags
-2001355
Detail Spritzbetonerdung TRK-3.dwg (2)
4728206
Signage
-2001058
Topography
-2001340
Casework Tags
-2005001
Project Information
-2003101
00007.dwg
4007941
00004.dwg
4006804
00002.dwg
4007852
00003.dwg
4006754
00001.dwg
4007769
Wall Tags
-2005011
Cable Tray Fitting Tags
-2008127
Structural Internal Loads
-2005204
Electrical Circuits
-2008037
Detail Spritzbetonerdung MAK-3.dwg
4519061
Analysis Display Style
-2000304
Pipe Insulations
-2008122
Food Service Equipment Tags
-2001045
Flex Ducts
-2008020
Duct Insulation Tags
-2008153
Plate Tags
-2009055
Rebar Cover References
-2009015
Assemblies
-2000267
Structural Load Cases
-2005210
Stair Support Tags
-2000942
Structural Area Reinforcement
-2009003
Structural Truss Tags
-2005030
Analytical Slab Foundation Tags
-2009656
Plan Region
-2000191
Structural Framing
-2001320
Mechanical Equipment Set Tags
-2000986
Structural Tendon Tags
-2006276
Electrical Fixtures
-2001060
Zufahrtsstollen-Profil.dwg
6116074
Air Terminal Tags
-2008014
Detail Spritzbetonerdung TRK-2.dwg
4728076
Vibration Damper Tags
-2006264
Data Devices
-2008083
Structural Annotations
-2006090
Lighting Fixtures
-2001120
Duct Insulations
-2008123
-2005110
Section Line
-2000201
Cable Tray Runs
-2008150
Section Marks
-2000400
Pipe Color Fill
-2008059
Generic Models
-2000151
Lighting Device Tags
-2008088
Floor Tags
-2005026
Sprinkler Tags
-2008100
Analysis Results
-2000303
Scope Boxes
-2006000
Line Load Tags
-2005251
Render Regions
-2000302
Structural Path Reinforcement Symbols
-2009010
Electrical Equipment
-2001040
Stair Landing Tags
-2000941
MEP Fabrication Containment Tags
-2008213
Curtain Panels
-2000170
Fire Alarm Devices
-2008085
Analytical Braces
-2009633
Temporary Structures
-2001039
Displacement Path
-2000223
Roads
-2001220
Duct Lining Tags
-2008154
Floors
-2000032
Flex Duct Tags
-2008004
Point Clouds
-2010001
Analytical Wall Foundation Tags
-2009655
Analytical Foundation Slabs
-2009643
Windows
-2000014
Structural Area Reinforcement Tags
-2009021
295777-1-CKTS9P3-1-3-GA - Längsschnitt Maschinenhallenkran.dwg (2)
4844246
295777-1-CKTS9P3-1-3-GA - Längsschnitt Maschinenhallenkran.dwg (3)
4845017
TRK OG Löschanlage GR.dwg (3)
3284665
SK_Kranbalken-Detail Kranbahnschiene.dwg
3986600
Bodenablauf bei Estrich.dwg
7623560
Pier Foundation Tags
-2006176
SK-B-TW2-UWS-0000-P-4-005-01_00 (RP SG2 VZ).dwg
4151728
TM_Kranbalken-Detail-2.dwg
4008088
-2009009
Stair Run Tags
-2000940
Rebar Shape
-2009013
Parts
-2000269
Nurse Call Device Tags
-2008078
Columns
-2000100
Area Load Tags
-2005252
Routing Preferences
-2008125
Generic Annotations
-2000150
Bodenablauf bei Estrich.dwg (2)
5397087
Bridge Decks
-2006135
Area Tags
-2005020
Abutment Pile Tags
-2006209
Analytical Pipe Connections
-2000983
View Reference
-2000197
Vertical Circulation
-2001052
Filled region
-2000190
Analytical Column Tags
-2009651
Structural Fabric Reinforcement
-2009016
Audio Visual Device Tags
-2001057
Connection Symbols
-2006100
Conduit Fitting Tags
-2008129
Raster Images
-2000560
Structural Column Tags
-2005018
Vibration Management
-2006261
Abutment Foundation Tags
-2006208
Analytical Beam Tags
-2009649
Adaptive Points
-2000900
Grid Heads
-2006040
Sections
-2000200
Mechanical Equipment Sets
-2000985
Room Tags
-2000480
Curtain Wall Mullions
-2000171
Stair Tags
-2005023
Signage Tags
-2001061
Structural Loads
-2005200
Revision Cloud Tags
-2006080
Walls
-2000011
Conduit Runs
-2008149
Duct Accessory Tags
-2008017
Spot Slopes
-2000265
Keynote Tags
-2005029
Space Tags
-2000485
Alignments
-2001012
Bridge Cable Tags
-2006173
Rebar Set Toggle
-2009025
Pipe Color Fill Legends
-2008058
Pipe Fittings
-2008049
3321024
Structural Columns
-2001330
Pipe Placeholders
-2008161
Guide Grid
-2000107
Grids
-2000220
Fire Alarm Device Tags
-2008086
Planting Tags
-2005021
Callouts
-2000537
Schedule Graphics
-2000570
Electrical Fixture Tags
-2005004
Telephone Device Tags
-2008076
Detail Injektionssperre_1.dwg
6843558
Structural Rebar Couplers
-2009060
Cable Trays
-2008130
Curtain System Tags
-2005025
Structural Stiffeners
-2001354
TRK OG Löschanlage GR.dwg (5)
3539376
Medical Equipment Tags
-2001048
Entourage
-2001370
MEP Fabrication Pipework
-2008208
Internal Line Load Tags
-2005254
Structural Fabric Reinforcement Symbols
-2009028
Bridge Deck Tags
-2006175
Mass Tags
-2003405
Zone Equipment
-2001010
Analytical Node Tags
-2000956
Expansion Joint Tags
-2006273
Property Tags
-2001267
Structural Path Reinforcement Tags
-2009011
Water Loops
-2001009
Callout Boundary
-2000539
Structural Area Reinforcement Symbols
-2009005
Contour Labels
-2000350
Nurse Call Devices
-2008077
3321493
Pier Wall Tags
-2006230
Areas
-2003200
Materials
-2000700
Roofs
-2000035
Structural Fabric Areas
-2009017
SK-B-TW2-KRA-0000-P-4-015-01_00 (RP VT1 2000).dwg (3)
4147384
Structural Rebar
-2009000
Reference Points
-2000710
Shaft Openings
-2000996
Vertical Circulation Tags
-2001054
Spot Elevation Symbols
-2005100
Curtain Wall Mullion Tags
-2005032
SK_Kranbalken-Detail Kranbahnschiene.dwg (2)
4408228
Internal Point Load Tags
-2005253
Analytical Isolated Foundation Tags
-2009654
TM_Kranbalken-Detail-3.dwg
4008090
Flex Pipe Tags
-2008048
Duct Fittings
-2008010
Cameras
-2000501
Elevations
-2000535
Specialty Equipment
-2001350
Analytical Floor Tags
-2009652
Pipe Accessories
-2008055
Detail Injektionen_2.dwg (3)
8752668
Structural Connection Tags
-2009040
Masking Region
-2000194
Expansion Joints
-2006271
Structural Rebar Coupler Tags
-2009061
Vibration Isolator Tags
-2006266
Structural Foundations
-2001300
Level Heads
-2006020
Road Tags
-2001221
Duct Color Fill Legends
-2007004
Analytical Beams
-2009630
Pier Tags
-2006171
Curtain Grids
-2000173
4147193
Path of Travel Tags
-2000834
Levels
-2000240
Brace in Plan View Symbols
-2006110
Railing Tags
-2000133
Structural Foundation Tags
-2005019
Wire Tags
-2008057
Security Devices
-2008079
Site Tags
-2005016
-2001043
Pipe Tags
-2008047
Weld Tags
-2009059
Analytical Link Tags
-2000955
Spot Coordinates
-2000264
Bearings
-2006138
00020.dwg
4006858
SK-B-TW2-UWS-0000-P-4-003-01_00 (RP SG2 3800).dwg
4153607
Detail Spritzbetonerdung VBK.dwg
4449192
Railings
-2000126
Viewports
-2000510
Abutment Tags
-2006170
SK_Kranbalken-Detail-Ankerkopf C1.dwg (2)
4424417
SK_Kranbalken-Detail-Ankerkopf C2.dwg (2)
4424564
Title Blocks
-2000280
Shear Stud Tags
-2009058
Pier Pile Tags
-2006226
Plumbing Fixture Tags
-2005010
Pier Tower Tags
-2006172
TRK OG Löschanlage GR.dwg (2)
3284593
Pipe Fitting Tags
-2008060
Duct Color Fill
-2008005
Stair Paths
-2000938
MEP Fabrication Pipework Tags
-2008209
Multi Leader Tag
-2005033
Bridge Framing Tags
-2006243
Bodenablauf ohne Estrich in Erstbeton-1cm.dwg (3)
8206664
Duct Linings
-2008124
Structural Beam Systems
-2001327
Roof Tags
-2000266
Detail Spritzbetonerdung TRK-1.dwg (2)
4727855
Views
-2000279
Sheets
-2003100
8206296
Casework
-2001000
Conduit Tags
-2008133
Point Load Tags
-2005250
Analytical Surfaces
-2008186
Structural Fabric Reinforcement Tags
-2009022
Material Tags
-2005027
View Titles
-2000515
-2001140
Parking Tags
-2005017
Structural Beam System Tags
-2005130
Alignment Tags
-2001015
Analytical Brace Tags
-2009650
Alignment Station Label Sets
-2001016
Structural Tendons
-2006274
Electrical Equipment Tags
-2005003
Generic Model Tags
-2005013
Switch System
-2008101
Furniture
-2000080
Rooms
-2000160
Hardscape
-2001036
Coordination Model
-2000982
Analytical Walls
-2009640
SK_Kranbalken-Detail-Konsole Bauhilfskran.dwg (2)
4446669
Hardscape Tags
-2001038
Stairs
-2000120
Text Notes
-2000300
Detail Items
-2002000
Spot Elevations
-2000263
Analytical Nodes
-2009645
Detail Spritzbetonerdung UMK.dwg (2)
4521360
Boundary Conditions
-2005301
Color Fill Legends
-2000550
Spaces
-2003600
Pier Cap Tags
-2006220
Dimensions
-2000260
Regelprofil EWS_2021-04-07.dwg
2497401
