in German language version of Dynamo 2.16 Category.ByName of “Ebenen” (levels) shows not “levels” but “Adaptive Punkte - Ebenen” (Adaptive working level).
Can Category.ByName be used with “OST_…” only?
Best regards
Rolf
maybe that helps…
Update your Revit to the latest release, and you should be ready. This was a known issue on the initial release of 2023
I have been using Category.ById lately as the string version is not consistent enough for my needs.
Hello John,
thank you very much for the information.
The good news: so the Revit 2023.1.1 update will fix the problem and the dyn scripts do not need to be changed!
The bad news: I could not install the update Revit 2023.1.1. So wait until the next issue.
Is “OST_” possibly the most stable solution for a long time?
Best regards
Rolf
I can’t really say for sure. But it seems like it might be as @Andreas_Dieckmann indicated in that other thread.
