Hi! I’m a new user in Dynamo. I have a prob with the “if statement”. I don’t see the mistake here (I’ve used the same function for another problem and it works!). I would be very thankful for any help
That’s a list with your number in it, not a number. Since you’re in Imperitive code Dynamo won’t make use of lacing or replication guides.
Try changing line 1 to t5 = a[0];
and wire your number into the a input of the code block.
Thanks! It works perfectly
