import sys
sys.path.append(r’C:\Program Files (x86)\IronPython 2.7\DLLs’)
sys.path.append(r’C:\Program Files (x86)\IronPython 2.7\Lib’)
import json
jsonPath = IN[0]
#Load Json
with open(jsonPath, "r") as read_file:
data = json.load(read_file)
for item in data:
Name = item["Naam"]
Location = item["Locatie"]
OUT = Location
i am using this code, but it won’t read my Json
"Naam": "Arno",
"Locatie":"D:\00_Algemeen\DynamoLogs"
File “”, line 15, in
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json_init_.py”, line 287, in load
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json_init_.py”, line 339, in loads
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json\decoder.py”, line 364, in decode
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json\decoder.py”, line 380, in raw_decode
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json\scanner.py”, line 37, in _scan_once
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json\decoder.py”, line 194, in JSONObject
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json\scanner.py”, line 35, in _scan_once
File “C:\Program Files\Autodesk\Revit 2020\AddIns\DynamoForRevit\IronPython.StdLib.2.7.8\json\decoder.py”, line 123, in py_scanstring
ValueError: Invalid \escape: ‘N’: line 3 column 26 (char 47)
