Was the json module not included in the implementation of Python included with Dynamo?
When attempting to import the module I get the following:
No module named json
Looks the problem is Dynamo doesn’t add library path to python evaluator.
The workaround is set the path in the code:
import sys
sys.path.append(‘C:\Program Files (x86)\IronPython 2.7\Lib’)
import json
Thanks, Yu Ke, that was the issue.
I hadn’t thought to look in the 32-bit folder.
-Bryan
