Can't install DYNAMO
My dynamo disappeared when I installed dynamo 1.3.
So I was re install revit and get dynamo 0.9.
But still can’t install 1.3 version.
Installation process is fine and there are no errors when I tried to install 1.3 version.
But there is still 0.9 version when after installation.
And 1.2, 1.1, 1.0 version has same status.
Is there another way to install dynamo?
In control panel go to programs and features can you uninstall any dynamo related programs ie. Dynamo for revit or dynamo core…restart machine and confirm if everything are uninstall. If you open revit check if you find dynamo anywhere on your ribbons. Once no dynamo version found try installing the dynamo version you desired.
