Hi all,
I’m trying to test Dynamo for Rebar pakage. As you can see the attached pic, i launch the rebar node, it’s not show any warnings but it’s not worked. Could you please explain it?
Thanks in advance.
Thanks for your respond!
Actually i found some errors and according to your workflow, i can make it work.
@lysonthien Could you show us how you want your workflow to be done? May be a sketch will do.
Yes, below is the dyn code. I used rebar following faces node, you can see in the attached file.rebar practice 1.dyn (28.1 KB)
