Kevin4
March 3, 2026, 8:16am
1
Hello all,
I am struggling to find the “View.SetFilterVisibility” node. I am seeing it exists in related posts (see below). But these unfortunately doesn’t help me in finding the node in dynamo.
Has it been removed? I am working in Dynamo Revit 3.3.0.6523. If it has been removed, how do we toggle the visibility of view filters now?
Related posts:
Hi all,
I am working on filters with Dynamo, different topics I have helped me a lot ! I am using Dynamo 2.0 or 1.3 sometimes to look for old nodes.
But I need the View.SetFilterVisibility() node and can’t find it. I have seen it exists but I can’t find it in my archi-lab package or in the others.
Do you have any idea ??
Thank you very much
Baudouin
I am having trouble adding a view filter to views and turning the visibility off.
I have a list of view filters (in watch node below) and a list of views that I want to apply only one filter parameter to. ie parameter.filter[0] is applied to view[0]. parameter.filter[1] is applied to view[1] etc.
When I use the View.AddFilter node from the archi-lab Grimshaw package by @Konrad_K_Sobon it applies all the view filters to every view, where as I only want a single view filter added.
When I use th…
Archi-Lab package if my memory and those posts are correct.
Kevin4
March 3, 2026, 10:24am
3
I have the Archi-lab package installed, but the View.SetFilterVisibility node doesnt seem to be included in there.
I did find Views.SetFilterOverrides, but it does not seem to behave like I was hoping.
Attached are my inputs to the nodes and the resulting view filters.
So, what are your trying to set / control?
Doesn’t these do what you want?
OR
Hi @Kevin4 maybe this could work for you
test view filters.dyn (4.8 KB)
Kevin4
March 3, 2026, 10:48am
6
I am trying to toggle the filter Visibility state. Both those nodes look like they should be able to do what I want, but they simply dont seem to trigger the desired effect.
Kevin4
March 3, 2026, 10:54am
7
Hello, the node you shared is almost exactly right. It is triggering the “Enable Filter” function of the desired filter instead of the “Visibility” function.
I guess you have to use @sovitek Python solution then.
Kevin4
March 3, 2026, 10:57am
9
Excuse me, I accidently replied to bvs1982. please see my response to your python node above!
allright then try as here and see if it better
clr.AddReference('RevitAPI')
view = UnwrapElement(IN[0])
filter = UnwrapElement(IN[1])
boolean = IN[2]
result = []
viewlist = []
try:
for i in view:
viewlist.append(i.SetFilterVisibility(filter.Id, boolean))
result.append(True)
except:
result.append(False)
OUT = (view,result)
Kevin4
March 3, 2026, 11:05am
12
The new script doesnt seem to do anything to the filter as far as I can see.
arhhh my bad maybe here
views = IN[0] if isinstance(IN[0], list) else [IN[0]]
view_filter = UnwrapElement(IN[1])
state = IN[2]
results = []
for v in views:
view = UnwrapElement(v)
try:
f_id = view_filter.Id
if not view.IsFilterApplied(f_id):
view.AddFilter(f_id)
view.SetFilterVisibility(f_id, state)
results.append(True)
except:
results.append(False)
OUT = (views)
Kevin4
March 3, 2026, 11:24am
14
Yes! It works perfectly!
I dont think this node is able to handle lists, but i’ll manage without that.
Thank you very much for the help!
havent tried but it could handle list as well as i tried with views…hard coded in the code, or create a costum dyf so we have option for lacing…i guess
Kevin4
March 4, 2026, 9:38am
18
View.SetFilterOverrides was my first instinct to use but I could not get it to work for me unfortunatly.
