Hi, i’m trying to put random materials on panels, bt i have an error at the end of the script each time, i don’t understand the problem the problem
here’s the script that i did
Did you look at the error? There is no parameter with that name. Either it’s misspelled (parameters are case sensitive) or it’s a type parameter not available to the element instances.
