Hello Dynos,
I dont know why, I just want select rooms from a linked file, it doesnt work
KR
Andreas
Can you show us the preview of the Get All Elements from Linked Model node?
Have you checked for unplaced Rooms in the linked model?(they have no geometry)
Can you try Geometry+?
Get All Elements from Linked Model asks for LinkDoc, not the link instance. I think Clockwork and some other packages have nodes for linked files that provides the actual linkdoc. Use that instead.
@kennyb6
Good catch
Hello everyone,
I’ve looked everywhere for the Get Document node, but I can’t find it.
Any help would be greatly appreciated — thank you in advance!
That specific node is from archilab. You will also find a similar node that also collects background documents in Crumple (Revit.GetDocuments), as well as a revit link instance/type collector node undet the Collectors node section.
Typically i use this node followed by Revit.GetDocument in Crumple to get the corresponding document related to the link itself:
Excuse me, why i don’t looking collector.elementsofcategoryindocument node?
which the package is it? thank you in advance!
looks like archilab, but similar can be find in clockwork, spring, bimorph, and probably many more
Found it. Thank you for very much!
